Re: Need wiring diagram for 12v single wire altern
Posted by Bob M on May 30, 2007 at 11:24:09 from (151.190.254.108):
In Reply to: Need wiring diagram for 12v single wire alternator posted by Karl T Schwab on May 30, 2007 at 11:10:30:
Punch below for a link to the exact diagram you need.
As for testing the alternator at the parts store, sounds like the guy there doesn't know much about it! For a one wire unit all they gotta do is mount it on the stand, connect the tester output lead and spin it up. If the alternator is good it'll show around 14.5 volts, and output amps somewhere in the neighborhood what's stamped on the alternator case. (One-wire alternators are usually stamped 42, 55 or 61 amps)
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
