international 2500
Posted by ih newbie on May 30, 2007 at 15:09:48 from (63.131.9.239):
I just bought an international 2500 backhoe that needs some tlc.
I think that the clutch is almost due a change but I wanted to
inspect it first. (I haven't gotten a service manual yet) so I ask the
local ih dealer/mechanic about it and he said it is a dry clutch
and there is an inspection plate on the bottom remove it and I
can see the clutch, that is what I did about an hour ago and got
soaked with hyd. oil when the inspection plate poped loose. I
put it back up and came in here to seek some counsel. Why if in
deed this is a dry clutch would I get soaked? if it is a wet clutch
is there any adjustment inside the case if the only adjustment is
the rod going to the pedal then I think it is a clutch replacement
because the clutch does not act like it fully engages when the
pedal is released, in the higher gears it slips pretty bad.
also if anyone has a lead on a cylinder for the boom I am
needing one of them.
thanks in advance
Ben
