Re: 1206 Hytrans draining question
Posted by Asking Again ..... on May 30, 2007 at 18:09:05 from (64.42.242.32):
In Reply to: Re: 1206 Hytrans draining question posted by the tractor vet on May 30, 2007 at 16:17:10:
Thanks, I will have a closer look for those other plugs. The oil in the final drives might be hytrans, for sure it is not continuous with the tranny oil which is water-polluted badly. The final drive oil is not as thick as gear lube now that I think of it, more like engine oil viscosity, maybe it is hytrans oil. It is somewhat dark colored like used engine oil. I'm going to leave that in there since it is definitely not mixing with the tranny oil. The problem is that the filters continually fail due to this water or moisture problem that keeps cropping up and once that happens, steering, etc. shuts down. I just want to make sure all of the tranny oil is out before refilling. I'm not sure exactly where you are referring to about the other two plugs, can you be more specific? Forward, left, right, etc? Thanks again for your help.
