Suoer H on propaine stage 2 live hyd
Posted by jonnnny2006 on May 31, 2007 at 00:21:14 from (67.142.130.23):
I know where there is a stage 2 super H that has a M propaine ensen carb set up on it. Its really nice propaine set up all ensen parts. the motor cant run because some one stole the distributer and live hydrolic setup. the engine still turns over by hand so its not stuck. but it needs all tires. has single front wheel. the stearing wheel sucks. needs work. but its one of those rare stage 2 1953's Also it has all correct Y codes. how much is it worth I wanna have a propaine setup as propaine is still cheep. (not like it was .99 but 1.50 not bad compared to gas. Also i wonder would the super h on propaine have a diffrent higher compression head? what should i offer him? i was thinking mabey 400 or 500??? mabey 300 because the tires are gone!
