Loose Steering on 400
Posted by super99 on May 31, 2007 at 02:12:57 from (207.144.199.121):
third party image
Took the loader off of my 400 to use to spray with. The steering is so loose that it is difficult to keep on the row. It has a Char-lynn PS unit on it and coupler between the steering shaft and the orbit motor is where the worst slop is. I took it apart, the hole in the shaft on the orbit motor is smaller than 3/8, a 11/32 drill bit will go thru it. The coupler has 3/8 holes in it and is wore enough that it is wobbles on the shaft. The knuckle on the steering shaft fits loosely on the other end of the coupler shaft and wobbles there too. The shaft on the orbit motor is too hard for my drill bits to make the hole 3/8's. Anyone have any ideas on how to tighten up the steering? Can you buy a new coupler? Where do you find a pin the right size to fit the hole snuggly? It has a roll pin that is too small in it and must be wired in to keep from loosing it. Open to any thoughts or sugestions. thanks, Chris
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
