Re: grinding going in gear
Posted by Dave BN on June 01, 2007 at 10:42:18 from (12.150.39.131):
In Reply to: grinding going in gear posted by don sloan on June 01, 2007 at 10:22:33:
The oil (grease) leak is a bad seal on the differental shaft. The opening for the brake rod is just the easiest place for it to come out. Try pushing the shift lever straight forward of the reverse position and hold it there for a few seconds before putting the transmission in gear, that might help the grinding. Sounds like your transmission grease is thin(waterlogged) or you have a bad pilot bearing. Dave.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
