Re: farmall 100 charging
Posted by John T on June 01, 2007 at 16:19:06 from (66.244.83.147):
In Reply to: farmall 100 charging posted by jeeper on June 01, 2007 at 16:07:23:
If you change ground polarity then YES you should swap coil leads. BOTTOM LINE IS the coil polarity needs to match your battery polarity i.e. if Pos ground its the coils + terminal to the distributor (- gets voltage from switch) while if its Neg ground then the coils lil - terminal wires to the distributor. When you change from 6 to 12 volts you can EITHER use the old 6 volt coil but add an external series voltage dropping (12 to 6) Ballast Resisistor after the switch and before the coil OR ELSE use a true full 12 volt rated coil no ballast required. A generator can still work at EITHER Pos or Neg ground regardless if 6 or 12 volt, you just have to polarize it correctly and the coil (per above) and ammeter leads need to be wired correct or it will read bass ackwards. Dont forget to change any lights to 12 volts. John T
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
