Re: Busted Brake Cover
Posted by Janicholson on June 01, 2007 at 19:32:23 from (66.173.50.117):
In Reply to: Busted Brake Cover posted by Clarkbug on June 01, 2007 at 19:18:23:
The bolt is an adjuster to keep the band free of the drum when the brake is released. Fixing could be as easy as two washers, two nuts, and a bolt long enough to do the trick. Take the cover off to see what it does. It is not a critical element, but it does allow less brake drag, and better adjustment. JimN
