Re: Farmall C Fluids
Posted by Ed342 on June 01, 2007 at 20:55:09 from (216.234.99.202):
In Reply to: Re: Farmall C Fluids posted by achodges1 on June 01, 2007 at 19:10:13:
achodges - Thanks for your help. I have a few clarification questions if you have the time. I have 2 Super C's, 1953 I believe. One has had a hard working life and the other looks like its lived the life of a country gentleman. However of the 4 plugs I am believing are filler plugs, all are identical. Each tractor has one at the 10 o'clock position by the shift lever base and one on top of the side pulley unit. Both have side pulleys. However all 4 plugs are identically rounded and concave on their hole bottoms. So similar, in fact, that it appears they were produced that way. There is no breakage at the edges or walls and the bottoms are all 4 smooth. Absolutely no signs of any breakage or use wear, and I'm looking very hard trying to find that on any of them. Not that they couldn't somehow have all turned out so perfect from breakage and wear but what a coincidence that would be. If these are the correct fill holes I am thinking of having something I can get a wrench on welded to their tops so I can turn them out and replace them. What's your thought on that approach?
It is correct, then, that the deck plug takes the 90 for the pto, differential and transmission and the plug on the side pulley services that unit only? 90 also?
I really appreciate all you folks who are so helpful here and the time you are taking to help.
Thanks
