Re: im not getting power that turns the mag
Posted by El Toro on June 02, 2007 at 03:37:29 from (152.163.100.197):
In Reply to: im not getting power that turns the mag posted by jonnnny2006 on June 02, 2007 at 00:00:53:
You will probably need to remove the front of the tractor, radiator, damper pulley and timing gear cover so you can see if you have a stripped gear or a sheared woodruff key. Hal
