Re: Super A lift
Posted by gene bender on June 02, 2007 at 03:45:43 from (67.55.226.214):
In Reply to: Super A lift posted by Cris on June 01, 2007 at 19:39:13:
Sounds like a leaky head gasket i would replace the fluid with just 30wt oil and see if that helps mite need to remove the filler plug and cycle the levers several times as you could also have some air in the system.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
