Re: im not getting power that turns the mag
Posted by russ hamm on June 02, 2007 at 06:32:19 from (63.245.179.200):
In Reply to: im not getting power that turns the mag posted by jonnnny2006 on June 02, 2007 at 00:00:53:
Dumb question, but here goes; are you sure you have it shifted off of diesel and to gas when you are checking the mag drive? If so, refer to the other's posts. Taking the front off is no real big deal. You will be way happier with it when it is right.
