F-20 Heisler OD removal
Posted by Scott in SC on June 02, 2007 at 14:14:08 from (64.12.117.8):
I’ve got an F-20 with Heisler Over Drive. The input seal on the OD is leaking, and I’d like to remove the unit, replace the seal and check the bearings as it has kind of a growl moving fast in high range.
It is attaché to the transmission by two bolts in the wholes that hold the cover for the top transmission bearing cover.
My question is, does anyone know if it has bolts threaded from the inside of the transmission to the OD. Or is it held on by two bolts?
Thanks,
Scott
