Re: What AGE DID U START DRIVING TRACTORS
Posted by RustyFarmall on June 02, 2007 at 15:03:01 from (66.43.253.62):
In Reply to: What AGE DID U START DRIVING TRACTORS posted by jonnnny2006 on June 02, 2007 at 13:55:35:
At age 5 or 6, I was driving the H through the gates 'cause I wasn't big enough to open that gate. By age 10 I was turned loose with that same H pullin' a hay rake.
