Farmall Tractors Discussion Board
Re: Checking Hydraulics on H
Posted by Phil Auten on May 10, 1999 at 06:09:51:
In Reply to: Checking Hydraulics on H posted by B. Batty on May 09, 1999 at 09:01:07:
Use Hy-Tran in the hydraulics. Fill to mark on the dipstick, if there is one. If no dipstick, check the level with a wire of some kind
and add Hy-tran until it seems to be full. This may take some trial and error to figure out, or if you can find another tractor to compare
with that might help.
Whatever you do, do NOT use detergent type motor oil in the hydraulics, it'll foam and screw everything up.
Phil
Post a Followup
: Re: Re: Checking Hydraulics on H
