Re: H Rear End bearing problems.
Posted by Bob Kerr on June 03, 2007 at 15:06:03 from (205.188.116.138):
In Reply to: Re: H Rear End bearing problems. posted by flying belgian on June 03, 2007 at 14:46:43:
Dad told me they busted a rear housing on one of grandpas tractors from a wheel bearing that came apart. The bull gear rammed a loose ball through the housing. On My H the LH axel was flopping and starting to rub the retainer but those cages are intact. New bearings will be here tues.
