Re: H Rear End bearing problems.
Posted by kfox on June 03, 2007 at 19:15:45 from (63.18.160.202):
In Reply to: Re: H Rear End bearing problems. posted by Bob Kerr on June 03, 2007 at 16:57:36:
Pilot bearing?? Remove the transmission input shaft before you remove the top.
ken
