Re: should there be fluid in the oil pump filter s
Posted by Owen Aaland on June 04, 2007 at 06:27:22 from (198.70.47.171):
In Reply to: should there be fluid in the oil pump filter scree posted by mark doud on June 03, 2007 at 19:04:28:
The oil pump pickup assembly is designed as
a float to allow the screen to ride up on the oil
rather than picking it up from the very bottom of
the pan. This was important when engines
were being run with non-detergent oils. Muck
would form on the bottom and the floating
pickup was an attempt to be able to draw
cleaner oil into the engine. IH went away from
this design it the sixties.
There should be a stop to prevent the pickup
screen from touching the bottom of the pan. If
it were to sit that low it could restrict the oil
intake and also wear through the pan.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
