Re: should there be fluid in the oil pump filter s
Posted by Mark Doud on June 04, 2007 at 08:22:12 from (207.68.116.74):
In Reply to: Re: should there be fluid in the oil pump filter s posted by El Toro on June 04, 2007 at 06:19:27:
Its from a super C. From another discussion its been indicated that there should be no liquid at all, and it probably has a pinhole leak. On closer inspection there appears to be a blob of jb weld or something similar on the top of the float.
Looks like I will need to take care of a leak.
Thanks for the reponses!
Mark D.
