Re: Battery Charging Help - Duh!
Posted by El Toro on June 04, 2007 at 09:01:45 from (152.163.100.197):
In Reply to: Battery Charging Help - Duh! posted by Jeff w/an H on June 04, 2007 at 08:25:14:
You probably need to take the battery to a shop where they can check out the battery. If its been dead a long time you may need to replace it.
You need to check your charging system to find out why it isn't keeping the battery charged. Hal
