Re: Anti-Sway part number for 140 HC
Posted by Richard J. Heath on June 04, 2007 at 13:05:59 from (64.12.117.8):
In Reply to: Re: Anti-Sway part number for 140 HC posted by Hugh MacKay on June 04, 2007 at 08:24:37:
Everyone is lost on this one. I think I have a 2 point hitch. There is a tool bar that a set of hippers fit on. This bar is supported by two lift arms that go under the tractor and are bolted at a pivot point and at a spot that has 2 holes that are chamfered to take a bolt such as a lug bolt. bolts are 1 1/4" headed. the vertical arms are connected to a cross piece seemingly attached fender to fender.
Any help?
