Re: Farmall Cub fan belt pulley
Posted by Denny ('60 Lo-Boy) on June 04, 2007 at 15:37:11 from (71.48.89.200):
In Reply to: Farmall Cub fan belt pulley posted by Farmall Freak on June 04, 2007 at 14:28:39:
Turn the pulley so the filler screw is at the 9 o'clock position (or 3 o'clock depending which way you are facing). Remove the screw or plug and fill with motor oil until it runs out. Then turn the hole down to the bottom and let the excess drain out. Replace the screw. It's a strange system and uses a slinger type mechanism.
