Re: Battery Charging Help - Duh!
Posted by KEB on June 04, 2007 at 20:18:56 from (72.19.170.5):
In Reply to: Battery Charging Help - Duh! posted by Jeff w/an H on June 04, 2007 at 08:25:14:
What kind of a charger are you using? The modern "computer controlled" versions can't tell when they're connected to a battery unless there's at least some charge in the battery to start with. It seems really silly to me to have a charger design that can't charge a completely dead battery...isn't that why we have battery chargers in the first place?
I have an old 4 amp transformer/rectifier type charger that will put out voltage regardless of what's connected to it, and use that to bring the battery up to where a more modern higher capacity charger can tell its there.
If you leave a know charging source connected for some perioed of time (a couple hours) and it still isn't taking a charge, its time for a new battery.
Keith
