Re: What to do when the farmer makes a Dumba** mis
Posted by El Toro on June 05, 2007 at 05:55:08 from (64.12.117.8):
In Reply to: What to do when the farmer makes a Dumba** mistake posted by Matt_In_Michigan on June 05, 2007 at 05:46:27:
You should check with your local locksmith. See if there's a manufacturer's name on the switch and model number if it has one. You may be better off to pull the switch and take it along to the locksmith. I'm sure they can make a key
that will work. Hal
