Re: What to do when the farmer makes a Dumba** mis
Posted by Roger in Iowa on June 05, 2007 at 06:12:21 from (69.18.26.32):
In Reply to: What to do when the farmer makes a Dumba** mistake posted by Matt_In_Michigan on June 05, 2007 at 05:46:27:
You can get the broken piece out with a bobby pin. Take the pin and cut it at the center of the "head". Use the straight side of the pin, throw the rest away. Now trim the center rounded end less and less until it will slip down along the back side of the broken piece, not the tooth side. It will "hook" around the tip of the key and you can usually pull it out.
Roger in Iowa
