Re: Cub Wont Start After Belt replacement!
Posted by kc2202 on June 05, 2007 at 08:45:52 from (68.50.54.221):
In Reply to: Re: Cub Wont Start After Belt replacement! posted by Andy Motteberg on June 05, 2007 at 08:39:00:
I was also worried that may be the case, It gets a little wet but i never expected it to be water. I assumed it was fuel. I rebuilt the carb and cleaned it many times. Should i pull the head and inspect? Do you have any tips i can follow? Thank you for your reply and help!
