Re: electronic ignition
Posted by John T on June 05, 2007 at 09:08:59 from (66.244.83.147):
In Reply to: electronic ignition posted by smdv806 on June 05, 2007 at 08:20:05:
Perhaps it was just BAD to begin with?? Other things may be that the current rating of the electronic switch was NOT compatible with the coil??? I believe some of the Pertronix Flame Thrower high energy coils require a higher current rated switch then their normal switch used for tamer or stock coils that draw less current. Grounds and wiring and connections can contribute to problems, but if its already fried you better check with pertronix and hope your switch was matched up for whatever coil you used. If you used the old stock coil the off the shelf elec switch should have handled that fine. I guess your switch matched your tractor voltage and ground?? If you were using a 6 volt coil on a 12 volt tractor and didnt use a current limiting voltage dropping (12 to 6) ballast resistor the switch would see way too much current and may overheat. John T
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
