Re: electronic ignition
Posted by dwag on June 05, 2007 at 10:38:42 from (74.40.170.74):
In Reply to: electronic ignition posted by smdv806 on June 05, 2007 at 08:20:05:
Check that alt or gen is not over charging. Use a 12v coil with minimum 3 ohm resistance across small posts. Do not use an external resistor. Call and ask Mfg. for troubleshooting advice. Knock on wood, we"ve had very good luck with these units on all makes.
