Re: hydro 70 transmission swap
Posted by pete 23 on March 08, 2009 at 19:49:33 from (173.87.1.12):
In Reply to: hydro 70 transmission swap posted by Lyndell on March 08, 2009 at 18:54:01:
That would be a real major project. Whole power train is different including flywheel on back to differential. Not sure if rear housing would even work as suction tube is different and not sure of bolt pattern to bolt on a torque amplifier housing. Then you would have mechanical and hydraulic connections difference also. The 656 is the forerunner to the 70 and the 666 and 686 are same vintage.
