Re: F12 needs constant choke
Posted by JeffL-TN on June 05, 2007 at 11:23:58 from (199.82.243.73):
In Reply to: F12 needs constant choke posted by Wisconsin Erick on June 05, 2007 at 10:26:52:
Check the gas tank for crud or rust etc. blocking fuel flow. My F12 had this problem after sitting for years. You get enough gas dribbling through to keep the flot bowl full static and to start but as soon as you start ther's insuficient flow to run the engine. Remove the sediment bulb, flush the tank and clean the sediment bulb screen. You may need to resort to extensive rust removal methods.
Good luck!
