Re: 6 volt generator is intermittent
Posted by CENTAUR on June 05, 2007 at 12:43:07 from (75.18.118.160):
In Reply to: 6 volt generator is intermittent posted by Wisconsin Erick on June 05, 2007 at 12:11:47:
I would first suspect the points need to be smoothed by the use of a thinner then normal point file (known as a regulator point file)or better yet a(RIMAC BRAND)FLEXSTONE #2 which is thin and 120 grit)The flexstone is the best.It will smooth and polish.Do not bend or adjust anything.Second make sure the brushes still are not worn down to where the contact is no longer sufficient on the commutator. CENTAUR
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
