Re: Farmall A Valves and Mag
Posted by El Toro on June 05, 2007 at 17:14:46 from (64.12.117.8):
In Reply to: Re: Farmall A Valves and Mag posted by bigr on June 05, 2007 at 17:08:23:
If you have the mag installed pull the coil wire from the cap and hold it near a good ground and have someone crank over the engine to see if there's fire from the coil wire. You may want to a pair od insulated pliers too. Hal
