Re: Super A stalls out
Posted by El Toro on June 05, 2007 at 17:29:43 from (64.12.117.8):
In Reply to: Re: Super A stalls out posted by JPM in WA on June 05, 2007 at 17:15:56:
I would remove it and see if the power is ok. You can hold a clean container under the gas line and open the shutoff valve to see if there's a good flow. Not just a trickle. Hal
