Re: Converting a Farmall A to 12 volt
Posted by John T on June 06, 2007 at 05:00:57 from (66.244.83.147):
In Reply to: Converting a Farmall A to 12 volt posted by history guy on June 05, 2007 at 20:20:02:
History, its your tractor and your choice if you wanna convert. If starting is a problem but you still wanna stay at 6 volts I recommend the biggest heaviest highest rated 6 volt battery that can physically fit into the battery compartment and the use of 00 Gauge battery n starter n ground cables. If converting to 12 volts you can EITHER keep the existing 6 volt coil (assuming its a distributor not a mag ignition) and add an external series voltage dropping (12 to 6) ballast resistor after the ignition switch ahead of the coil OR ELSE buy a full true 12 volt coil (some people call internally ballasted) no external ballast required. If you change polarity like from Pos to Neg ground (as most all alternators require) you would have to reverse ammeter leads or it reads bass ackwards. Wire the coil to match your ground i.e. if at Pos ground its lil + wires to distributor while if Neg ground its - wires to distributor with the other terminal, of course, getting voltage from the ignition switch/ballast. You can use a 12 volt genny or alternator, starter will work at 12 volts okay. John T
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
