Farmall Tractors Discussion Board
Re: Re: Re: Crud removal
Posted by Justin on May 11, 1999 at 13:11:45:
In Reply to: Re: Re: Crud removal posted by T-Tim on May 11, 1999 at 12:56:31:
Like Red stated, you don't want to snap any bolts, but it is a pretty easy job to do.. I would suggest trying to get an extra set of rails to use as a stand to lift the front end off of the ground.. this can be done, by bolting them into the bell housing. Also, unless you wish to remove the radiator and the whole front end,make sure you use a hydraulic lift to support the front end.. As for the removal, it is as easy as it looks, except fot the oil filter side.. to remove top bolt that holds the rail into the bell housing, it is necessary to remove the top left bolt from the oil filter base to allow the removal of the side rail bolt.. I would also suggest changing that gasket also.. Good luck if you decide to do it..
Post a Followup
: Re: Re: Re: Re: Crud removal
