Re: Tractor Vet..Need Your Help
Posted by the tractor vet on June 06, 2007 at 17:51:37 from (75.19.120.54):
In Reply to: Tractor Vet..Need Your Help posted by Allan In NE on June 06, 2007 at 16:28:42:
well on a hyd. clutch ya want 9/16th free travel from the back of the pedal shaft to the floor board , there is and arrow on the clutch pedal massure from the arrow to the floor board with the engine off and see what ya got . and if ya need to make any adjustments will go from there also check and make sure that the cylinder is not getting loose on the mounting bolts . To make the adjustments first unhook the trans brake and the foward clutch rod by removing the pins , next puh the clutch rod as far back into the cylinder next loosen the lock nuts on the rear clutch rod and adjust till ya feel resistance and lock it down . Now ya want to get place something that is 9/16th. thick between the clutch pedal and the floor plate , then ya hold the clutch bell crank foward till ya feel the throw out bearing touchen the clutch and then adjust the front rod out till ya can slide the pin in freely . Next ya want to adjust the trans brake ( this is when ya need a spare foot to hold the clutch pedal down aganist the stop loosen the lock nut on the trans brake rod on the right side of the tractor with your hand hold the lever of the trans brake back then adjust the clevis till the pin will slide in once this is done let the clutch up (tractor does not have to be running for this )next add one turn to the clevis , now depending on ware of all the linkage due to age and ware ya may have to go 1 1/2 turns ans at times i have had to go 2 turns to get it to work correctly . Next it is the dump valve here the engine MUST be running tractor in PARK here again it needs a helper . First back the dump valve adjusting bolt out about 5-6 full turns Depress the clutch pedal down to the stop and hold , the RED teltale light should be on now start turning the adjusting bolt into the clevis and turn till the teltale lite just goes out as soon as it goes out STOP let the clutch pedal up shut off tractor then add ONE MORE FULL TURN TO THE BOLT AND LOCK . Test drive tractor.
Home
| Forums
Today's Featured Article -
Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
