Re: 656 shifter rails
Posted by MN Scott on June 07, 2007 at 20:21:54 from (206.9.216.83):
In Reply to: 656 shifter rails posted by dtk on June 07, 2007 at 19:15:44:
If they are the same as on a 686, yes you can. I replaced mine a year ago. I removed the battery and the lower steering coluom. You have to support the upper coloum with a hoist. I then drilled a hole in the seal and installed a self tapping screw. I pryed out the seal with a bar under the head on the screw. Clean every thing up and carefully tap the new seals in place. Was an fairly easy job, just took same time. Much easier than pulling the whole cover.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
