Re: Hydraulic flare connections
Posted by Owen Aaland on June 08, 2007 at 00:29:51 from (198.70.47.162):
In Reply to: Hydraulic flare connections posted by PaulW_NJ on June 07, 2007 at 05:21:02:
Flair fittings on hydraulic lines are 37 1/2 degrees. Usually single flair with a support flange between the flair and the nut. The hydraulic tubing is heavier wall than brake lines and you will not be able to double flair it.
