Re: gas addative
Posted by gene bender on June 08, 2007 at 02:24:08 from (67.55.226.214):
In Reply to: Re: gas addative posted by F-Dean on June 07, 2007 at 18:25:52:
Here in IOWA we have been using the ethanol 10% mix for over 25yrs with no problems tractors sit for the winter and start every spring without any additives ect. Some i shut the gas off at the sediment and let the carb run dry and others is just hit the sw.
