Re: How do I increase voltage for 8V batt on by B?
Posted by gene bender on June 08, 2007 at 06:45:37 from (67.55.226.214):
In Reply to: How do I increase voltage for 8V batt on by B? posted by Wayne from Iowa on June 08, 2007 at 05:10:26:
your system must have a leak somewhere for the batt to go dead unless the batt is bad. check the cells with a hydrometer to see condition. you dont have to do anything when going to an 8v batt as it will keep the batt up in good shape. i know of a couple that run 8v batts and they never have any problems they all just bought an 8v batt stayed with the pos ground and have been that way for several years.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
