Re: Super A won't start/run
Posted by Janicholson on June 09, 2007 at 11:09:28 from (66.173.50.160):
In Reply to: Super A won't start/run posted by Mark (PA) on June 09, 2007 at 09:51:17:
Old has it! The fuel supply is most likely. If it comes out of the drain (with the tank turned on), like it was comming out of a small sweetheart soda straw, the supply is not the problem. Catch the gas in a tincan. The coil could be failing, but less likely. JimN
