Re: 1941 H carborator flooding.
Posted by Aaron B on June 09, 2007 at 17:33:12 from (71.82.145.210):
In Reply to: 1941 H carborator flooding. posted by Dave Phillips on June 09, 2007 at 17:22:43:
Are you sure the 'groove' is not just the tip developing a memory from sitting too long in the closed position? I doubt that a lead additive will help this, as the lead is intended to lubricate the valves. I am not aware of any manufacturers of solid metal needles, but that doesn't mean they don't exist. Personally, I would just install a new needle, and if it begins leaking again for the same reason, then I would begin to worry. I have not had any problems like this, running regular or ethanol thru my tractors, so it is possible you just got a defective needle. Good luck!
Aaron
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
