Re: Road Tire Pressure
Posted by Janicholson on June 09, 2007 at 18:15:44 from (156.99.211.221):
In Reply to: Road Tire Pressure posted by Piratefan on June 09, 2007 at 18:10:34:
I would not put that much pressure in any rear tractor tire. think of the internal surface area, and multiply that by the PSI, and you will be nervous. Use the regular pressure, or the max recommended pressure only. Though not obvious, tread wear will be very uneven with high pressure. JimN
