Re: Baling with SH
Posted by Hugh MacKay on June 09, 2007 at 19:05:26 from (209.226.106.172):
In Reply to: Baling with SH posted by GordoSD on June 09, 2007 at 07:41:38:
Gordon: The plunger knife is dull, and very likely the plunger is out of adjustment. Now, I realize you didn't have IPTO. Your Super H should be making 2nd gear in windrows the width of that pickup, and the crossbar flattening the windrow tops. If the Super H won't make 10 ton per hour with that baler, something is wrong with tractor or baler or both.
Believe me I have baled hay with pto drive S-69 powered by my Farmall 130, and baled 6-7 ton per hour. I was in same position as you, big tractors were busy.
