Farmall Tractors Discussion Board
Re: Lost Spark On The M
Posted by Phil Auten on May 12, 1999 at 09:32:21:
In Reply to: Lost Spark On The M posted by Rick Tobianski on May 11, 1999 at 19:04:41:
Rick,
Dan made the guess that your M has been converted to 12V and has a distributor type ignition. If your battery is 6V, you will only see 6V at the coil. I would start by checking as he said, then proceed to check That the rotor is turning, then check the point gap for .020" and then replace the condenser. If your M has a Magneto, write back and let us know. The Magneto has the coil mounted into the distributor and there are no wires connecting to it from the battery.
Phil
Post a Followup
: Re: Re: Lost Spark On The M
