Re: 140 adj. breaker point screw
Posted by Nawlens_Gator on June 10, 2007 at 09:23:32 from (74.230.198.183):
In Reply to: 140 adj. breaker point screw posted by hogsbackfarm on June 10, 2007 at 05:22:03:
I replaced that screw with one of those green ground screws that come with home electrical switches. It's 3/16" fine thread (about 20 or 25 threads / inch)and about 1/4" long (longer it will botom out before getting tight). The advantage is you can tighten with a ratchet.
Electronic ignition works better by the way.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
