Re: turn up 560
Posted by Hugh MacKay on June 10, 2007 at 19:43:48 from (209.226.247.112):
In Reply to: Re: turn up 560 posted by Armand Tatro on June 10, 2007 at 17:30:54:
Armand: It is well docomented tractors catching and slipping did not harm rear ends. We proved that here in Canada using Canadian ring chains on frozen and icy conditions. I've seen my 560 chewing a wheel track 3" deep in hard frozen ice, and let me tell you there was a lot more catch and slip than ever happened on summer fields.
It is well documented heat build up over many hours is what kills powertrains. I've talked with a few technicians, I'm told gears may have broken at the end but heat damage was the culpert. You whind out the hp then add 6,000# to rear wheels and you soon get heat.
