Re: turn up 560
Posted by Wardner on June 10, 2007 at 20:36:17 from (4.154.246.100):
In Reply to: Re: turn up 560 posted by Armand Tatro on June 10, 2007 at 17:30:54:
The 560 and 660 use the same pump and this can be verified in the parts book. The difference is 20 HP and it is achieved thru rpm. That would 1800 vs 2400. I expect the torque curves are the same thru 1800 rpm. And yes, the injectors are the same as well as the rest of the engine. It should be noted that there are early and late pumps and injectors.
