Hydraulic Tubing Size
Posted by PaulW_NJ on June 11, 2007 at 03:47:56 from (70.111.182.208):
I wanted to replace the hydraulic lines running back to the Fasthitch on my 340 with new steel tubing, and also run remote hydraulics lines to the rear. The existing steel lines coming out of the valve manifold are 5/8 inch OD. Do you think it would make a significant difference if I used 1/2 inch OD tubing instead? I realize the smaller diameter tube will have a greater pressure drop, but it"s only a couple feet, and 1/2 inch is much easier to work with.
