Clutch pedal wobbles
Posted by CopelandJ on June 11, 2007 at 13:29:13 from (134.161.228.210):
I sure need help. The clutch pedal on the Super M I"m working on wobbles terribley on the shaft -- as much as four inches side to side. The IH dealer showed the diagram related to this, and he says there was nothin on the shaft originaly to keep it from wobbling. He said the shaft is just worn, but the shaft sure doesn"t look worn. My guess is there was an insert of some type on the inside of the pedal where it is on the shaft that kept it level and without wobble. Since the IH dealer says there is no fix for this, I"ll have to find out what others have done to take care of this. Should I just put washers on the shaft on the inside toward the tractor to try to take up some slack so that the pedal doesn"t wobble so much, or should I machine something to put in the pedal housing where it goes on the shaft -- or on the shaft itself to take up the wobble? Any help will be greatly appreciataed. Take care. Jeff
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
